주요 콘텐츠로 건너뛰기
Bose SoundTouch 10 Back panel Replacement
필요한 것
  1. Bose SoundTouch 10 Back panel Replacement, Front Panel: 1 단계, 이미지 1/1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Back panel Replacement: 2 단계, 이미지 1/1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Back panel Replacement: 3 단계, 이미지 1/2 Bose SoundTouch 10 Back panel Replacement: 3 단계, 이미지 2/2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Back panel Replacement, Back panel: 4 단계, 이미지 1/1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Back panel Replacement: 5 단계, 이미지 1/1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Back panel Replacement: 6 단계, 이미지 1/2 Bose SoundTouch 10 Back panel Replacement: 6 단계, 이미지 2/2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Back panel Replacement: 7 단계, 이미지 1/2 Bose SoundTouch 10 Back panel Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Back panel Replacement: 8 단계, 이미지 1/2 Bose SoundTouch 10 Back panel Replacement: 8 단계, 이미지 2/2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
James Asbury
회원 가입일: 04/10/17
898 평판
안내서 5개 작성하였습니다
Cal Poly, Team S13-G1, Forte Spring 2017 Cal Poly, Team S13-G1, Forte Spring 2017 회원
CPSU-FORTE-S17S13G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
How can I install a 12v battery?
Quique - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 35
전체 시간: 6,675
