소개
The Bose SoundTouch 10 bass port is a hollow plastic tube inside the speaker. Removing it allows you to clean out any dust/dirt that may be trapped inside. It also allows access to other components inside the speaker that are usually covered by the bass port.
The motherboard in this guide contains capacitors which can hold a charge even when the speaker is powered off. Do not touch the as it may result in a shock.
필요한 것
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
다른 2명이 해당 안내서를 완성하였습니다.
