주요 콘텐츠로 건너뛰기
Bose SoundTouch Portable Motherboard Replacement
필요한 것
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: 1 단계, 이미지 1/1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: 2 단계, 이미지 1/1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: 4 단계, 이미지 1/1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: 5 단계, 이미지 1/1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: 7 단계, 이미지 1/3 Bose SoundTouch Portable Motherboard Replacement: 7 단계, 이미지 2/3 Bose SoundTouch Portable Motherboard Replacement: 7 단계, 이미지 3/3
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: 8 단계, 이미지 1/3 Bose SoundTouch Portable Motherboard Replacement: 8 단계, 이미지 2/3 Bose SoundTouch Portable Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea Martin
회원 가입일: 02/20/17
697 평판
안내서 6개 작성하였습니다
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 34
전체 시간: 2,957
