주요 콘텐츠로 건너뛰기
Bose SoundTouch Portable Speaker Replacement
필요한 것
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: 1 단계, 이미지 1/1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: 2 단계, 이미지 1/1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: 4 단계, 이미지 1/1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: 5 단계, 이미지 1/1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: 6 단계, 이미지 1/1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: 7 단계, 이미지 1/1
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: 8 단계, 이미지 1/3 Bose SoundTouch Portable Speaker Replacement: 8 단계, 이미지 2/3 Bose SoundTouch Portable Speaker Replacement: 8 단계, 이미지 3/3
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chelsea Martin
회원 가입일: 02/20/17
697 평판
안내서 6개 작성하였습니다
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,816
