소개
Having trouble turning your speaker on? Then you probably need to replace the battery. This guide will show you how to properly replace the battery of the Bose Soundlink Flex speaker. Otherwise, the speaker's battery may be dead; it takes around 4 hours to charge to 100%.
필요한 것
Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
Lift the driver out, being cautious of the wires still connected to the device.
다른 한 분이 해당 안내서를 완성하였습니다.
