주요 콘텐츠로 건너뛰기
Bose Soundlink Flex Charging Port Replacement
필요한 것
  1. Bose Soundlink Flex Charging Port Replacement, Grille: 1 단계, 이미지 1개 중 1개
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Bose Soundlink Flex Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Charging Port Replacement, Charging Port: 4 단계, 이미지 3개 중 1개 Bose Soundlink Flex Charging Port Replacement, Charging Port: 4 단계, 이미지 3개 중 2개 Bose Soundlink Flex Charging Port Replacement, Charging Port: 4 단계, 이미지 3개 중 3개
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Charging Port Replacement: 5 단계, 이미지 3개 중 1개 Bose Soundlink Flex Charging Port Replacement: 5 단계, 이미지 3개 중 2개 Bose Soundlink Flex Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
  6. Bose Soundlink Flex Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Bose Soundlink Flex Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
  7. Bose Soundlink Flex Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Bose Soundlink Flex Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard by sliding the charging port out of the case.
결론
작성자
2다른 기여자 명과 함께
Kalvin Lee
회원 가입일: 03/19/24
435 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G1
3 회원들
안내서 6개를 작성함
댓글 한 개
Where did you get the port from ?
asdrubalaburto - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 89
전체 시간: 795
