주요 콘텐츠로 건너뛰기
Bose Soundlink II Battery Replacement
필요한 것
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: 1 단계, 이미지 1/1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: 2 단계, 이미지 1/1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: 4 단계, 이미지 1/2 Bose Soundlink II Battery Replacement: 4 단계, 이미지 2/2
    • Carefully remove the battery by pulling it out of the speaker.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Kevin Bailey
회원 가입일: 09/24/15
464 평판
안내서 2개 작성하였습니다
Texas Tech, Team 22-4, Rauch Fall 2015 Texas Tech, Team 22-4, Rauch Fall 2015 회원
TTU-RAUCH-F15S22G4
3 회원들
안내서 3개 작성하였습니다
댓글 11개
Where i can buy one them battery model?
Daniel Campos - 답글
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - 답글
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - 답글
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - 답글
How much the battery only
Joboy De Guzman II - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 47
30일 전: 268
전체 시간: 32,670
