필요한 것
Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 11개
Where i can buy one them battery model?
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
Thanks, Bob.
bobveitch4 - 답글
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
How much the battery only
