주요 콘텐츠로 건너뛰기
Bose Soundlink II Button Cover Replacement
필요한 것
  1. Bose Soundlink II Button Cover Replacement, Bose Soundlink II Cover Removal: 1 단계, 이미지 1/1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Button Cover Replacement: 2 단계, 이미지 1/1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Button Cover Replacement, Side Cover: 3 단계, 이미지 1/1
    • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
  4. Bose Soundlink II Button Cover Replacement: 4 단계, 이미지 1/1
    • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
  5. Bose Soundlink II Button Cover Replacement: 5 단계, 이미지 1/3 Bose Soundlink II Button Cover Replacement: 5 단계, 이미지 2/3 Bose Soundlink II Button Cover Replacement: 5 단계, 이미지 3/3
    • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
  6. Bose Soundlink II Button Cover Replacement, Button Cover: 6 단계, 이미지 1/1
    • Once the Bose Soundlink II Side Covers Removal has been completed, remove the two screws (13 mm) an inch below the buttons on the back of the speaker using the T-10 star tip screwdriver.
  7. Bose Soundlink II Button Cover Replacement: 7 단계, 이미지 1/1
    • Using a tool such as a spudger or plastic opening tool, insert the end into one of the small indentations located on the back of the speaker. Start either on the indentation farthest to the right or to the left.
    • Pry up with the spudger or plastic opening tool so that the cover is pushed up slightly.
  8. Bose Soundlink II Button Cover Replacement: 8 단계, 이미지 1/1
    • Repeat this process with each of the indentations, working your way left or right (depending on where you start).
  9. Bose Soundlink II Button Cover Replacement: 9 단계, 이미지 1/1
    • Pull the cover around the buttons off. If you’d like, you can remove the button cover as well.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John P Loughran
회원 가입일: 03/02/17
448 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G3, Harley Spring 2017 IUPUI, Team S3-G3, Harley Spring 2017 회원
IUPUI-HARLEY-S17S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 2,144
