주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose Soundlink III Battery Replacement
필요한 것
  1. Bose Soundlink III Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose Soundlink III Battery Replacement: 2 단계, 이미지 2개 중 1개 Bose Soundlink III Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose Soundlink III Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose Soundlink III Battery Replacement: 4 단계, 이미지 2개 중 1개 Bose Soundlink III Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dakoda Sanders
회원 가입일: 02/04/16
1,612 평판
안내서 4개를 작성함
USF Tampa, Team 3-2, Wollert Spring 2016 USF Tampa, Team 3-2, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G2
4 회원들
안내서 8개를 작성함
28가이드 댓글
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - 답글 공유
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - 답글 공유
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - 답글 공유
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - 답글 공유
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 101
지난 30일: 382
전체 시간: 69,842
