소개
The buttons no longer work properly, react only with strong pressure or multiple presses? Then you probably also have the Bose-series error, which occurs after a long time.
필요한 것
To access the microswitches, you have to remove the rubber strip for the operation with the symbols ON/ - / o / + /|.
This is easily done with a fingernail. Simply "hook" (press into the space between the rubber and the housing) one corner of the strip with your fingernail and then move your finger towards the rubber. The rubber strip is simply inserted into the groove along the housing, so it will come off quite easily.
Now you can see the "series defect" or planned obsolescence in most cases. The keys / microswitches are coated with some type green grease on top. This grease "creeps" over time into the space between the button housing and the button. This grease has to be removed from the keys.
I used contact spray to clean it. However, alcohol should also work. Using very small or pointed tweezers, grab a small piece of kitchen paper or absorbent cotton and remove the visible grease from the button that is no longer working properly.
Now very CAREFULLY spray a little contact spray on the gold part or the space, between the gold "pusher" and the push button housing. Wipe along the golden element with the tweezers and the small piece of cloth, also press the button a few times.
Now you can remove the sticky lubricant from the space between the push-button element (gold) and the housing (silver) by "spraying" droplets and wiping around it, always changing the cloth. This procedure must be repeated very often - at least 20 times, until the absorbent cloth no longer turns green.
During the process you can see or feel, that the golden element can be pressed easier, or even turned again easily, which was not possible before. The often missing pressure point, the "key click" can also be felt again.
If everything is working well again and all keys that were "stiff" are working again, then you can replace the rubber strip. To do this, simply insert the rubber strip into the housing groove at one corner and then press it into the groove all around.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
