이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the AUX/USB port in your device.
필요한 것
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
Remove the AUX/USB port from the device.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 17개
Did you ever manage to find a place to buy it?
You can buy a charging cradle for this device, maybe that helps..
adsf -
Try buying the wireless charger for $29: https://www.bose.com/en_us/products/spea...
I am also looking for the usb port replacement part.
