주요 콘텐츠로 건너뛰기
Bose Soundlink Revolve Bottom Circuit Board Replacement
필요한 것
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: 1 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: 1 단계, 이미지 2개 중 2개
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Bose Soundlink Revolve Bottom Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Bose Soundlink Revolve Bottom Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Bottom Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Bottom Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 5 단계, 이미지 3개 중 1개 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 5 단계, 이미지 3개 중 2개 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 5 단계, 이미지 3개 중 3개
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: 6 단계, 이미지 1개 중 1개
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian Butner
회원 가입일: 09/27/17
912 평판
안내서 3개를 작성함
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G2
4 회원들
안내서 4개를 작성함
43가이드 댓글
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - 답글
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - 답글
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - 답글
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 44
지난 30일: 247
전체 시간: 16,603
