주요 콘텐츠로 건너뛰기
Bose Soundlink Revolve Top Circuit Board Replacement
필요한 것
  1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: 1 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: 1 단계, 이미지 2개 중 2개
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Top Circuit Board Replacement: 2 단계, 이미지 3개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement: 2 단계, 이미지 3개 중 2개 Bose Soundlink Revolve Top Circuit Board Replacement: 2 단계, 이미지 3개 중 3개
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Top Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Top Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: 5 단계, 이미지 1개 중 1개
    • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
  6. Bose Soundlink Revolve Top Circuit Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the (4) four screws shown around the top of the inside.
    • (2) two of the screws are shown here, the other side will look the same.
  7. Bose Soundlink Revolve Top Circuit Board Replacement: 7 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement: 7 단계, 이미지 2개 중 2개
    • Pry up and remove the soft plastic casing from the rest of the device.
  8. Bose Soundlink Revolve Top Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Bose Soundlink Revolve Top Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 3 screws holding down the top circuit board.
  9. Bose Soundlink Revolve Top Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • Lift up and look on the underside of the circuit board.
    • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian Butner
회원 가입일: 09/27/17
912 평판
안내서 3개를 작성함
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G2
4 회원들
안내서 4개를 작성함
13가이드 댓글
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - 답글
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - 답글
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - 답글
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - 답글
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 32
지난 30일: 189
전체 시간: 14,888
