주요 콘텐츠로 건너뛰기
Bose Wave Radio AWR1-1W Front Grill Replacement
필요한 것
  1. Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: 1 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: 1 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: 1 단계, 이미지 3/3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  2. Bose Wave Radio AWR1-1W Front Grill Replacement: 2 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Front Grill Replacement: 2 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Front Grill Replacement: 2 단계, 이미지 3/3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  3. Bose Wave Radio AWR1-1W Front Grill Replacement: 3 단계, 이미지 1/1
    • Lift the front grill away from the device.
결론
To reattach the front panel, press it into the front of the device until it pops back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
Cassie Harriman
회원 가입일: 04/18/17
1,033 평판
안내서 5개 작성하였습니다
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,808
