주요 콘텐츠로 건너뛰기
Bose Wave Radio AWR1-1W Speaker Replacement
필요한 것
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: 1 단계, 이미지 1/2 Bose Wave Radio AWR1-1W Speaker Replacement, Base: 1 단계, 이미지 2/2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: 2 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 2 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 2 단계, 이미지 3/3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: 3 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 3 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 3 단계, 이미지 3/3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: 4 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 4 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 4 단계, 이미지 3/3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: 5 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 5 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 5 단계, 이미지 3/3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: 6 단계, 이미지 1/1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 7 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 7 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 7 단계, 이미지 3/3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: 8 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 8 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 8 단계, 이미지 3/3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: 9 단계, 이미지 1/1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 10 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 10 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 10 단계, 이미지 3/3
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: 11 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 11 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 11 단계, 이미지 3/3
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: 12 단계, 이미지 1/3 Bose Wave Radio AWR1-1W Speaker Replacement: 12 단계, 이미지 2/3 Bose Wave Radio AWR1-1W Speaker Replacement: 12 단계, 이미지 3/3
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Cassie Harriman
회원 가입일: 04/18/17
1,033 평판
안내서 5개 작성하였습니다
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 25
30일 전: 84
전체 시간: 6,937
