주요 콘텐츠로 건너뛰기
Bose portable speaker battery Replacement
필요한 것
    • flip speaker over onto its back
    • using a heat gun, soften the adhesive holding the ring in place.
    • peel off the ring that covers the screws
    • using your screwdriver, undo the 4 screws that hold the base onto the body of the speaker.
    • using your heat gun, apply a slight amount of heat to soften the adhesive.
    • during reassembly, apply the new adhesive.
    • using your screwdriver, undo the 4 screws holding the speaker assembly in place.
    • carefully pry in the edge of the speaker assembly.
    • be very careful when prying as it is still connected to the motherboard wires.
    • using a spludger, carefully disconnect the speaker cables from the motherboard.
    • be very careful not to damage the connector.
    • using your spludger, carefully pry up the battery.
    • be very careful not to puncture the battery.
    • using 2 fingers, pinch the connector connecting the battery and pull it straight out.
결론
776831
회원 가입일: 06/10/21
1,085 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 30
전체 시간: 326
