주요 콘텐츠로 건너뛰기
Bose-301 Series II Tweeter Replacement
필요한 것
  1. Bose-301 Series II Tweeter Replacement, Tweeter: 1 단계, 이미지 1/3 Bose-301 Series II Tweeter Replacement, Tweeter: 1 단계, 이미지 2/3 Bose-301 Series II Tweeter Replacement, Tweeter: 1 단계, 이미지 3/3
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: 2 단계, 이미지 1/1
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: 3 단계, 이미지 1/3 Bose-301 Series II Tweeter Replacement: 3 단계, 이미지 2/3 Bose-301 Series II Tweeter Replacement: 3 단계, 이미지 3/3
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: 4 단계, 이미지 1/2 Bose-301 Series II Tweeter Replacement: 4 단계, 이미지 2/2
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: 5 단계, 이미지 1/3 Bose-301 Series II Tweeter Replacement: 5 단계, 이미지 2/3 Bose-301 Series II Tweeter Replacement: 5 단계, 이미지 3/3
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: 6 단계, 이미지 1/1
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: 7 단계, 이미지 1/1
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: 8 단계, 이미지 1/2 Bose-301 Series II Tweeter Replacement: 8 단계, 이미지 2/2
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
결론
To reassemble your speaker, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Patrick Emery
회원 가입일: 01/09/17
174 평판
안내서 1개 작성함
USF Tampa, Team 15-3, Remmell Spring 2017 USF Tampa, Team 15-3, Remmell Spring 2017 회원
USFT-REMMELL-S17S15G3
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 54
전체 시간: 7,182
