주요 콘텐츠로 건너뛰기
Boss RC-1 Loop Station-Pedal Battery Replacement
필요한 것
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: 3 단계, 이미지 2개 중 1개 Boss RC-1 Loop Station-Pedal Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
결론
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 19
지난 30일: 79
전체 시간: 7,108
