주요 콘텐츠로 건너뛰기
소개
The audio cable is easy to remove. This requires absolutely no repair skills.
  1. To start, make sure that the headphones are disconnected from any audio source.
    • To start, make sure that the headphones are disconnected from any audio source.
  2. Fold the earpads flat.
    • Fold the earpads flat.
  3. Pull off the earpad. When putting the earpads back on, make sure that the groove in the earpad is facing towards the top of the headphones.
    • Pull off the earpad.
    • When putting the earpads back on, make sure that the groove in the earpad is facing towards the top of the headphones.
  4. Take the audio cable out of the clip.
    • Take the audio cable out of the clip.
  5. Pull out the audio cable.
    • Pull out the audio cable.
  6. Headphones remain.
    • Headphones remain.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ashley Ryan
회원 가입일: 2012년 03월 25일
5,240 평판
안내서 3개 작성하였습니다
Master Techs Master Techs 회원
Community
297 회원들
안내서 983개 작성하였습니다
I replaced cable once and all was fine. Now left side only not working. Could it be something else or just time for a new cable?
Jayrosen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 77
전체 시간: 7,379
