주요 콘텐츠로 건너뛰기
Bowers and Wilkins P5 Headphones Audio Cable Replacement
  1. Bowers and Wilkins P5 Headphones Audio Cable Replacement, Earpads: 1 단계, 이미지 1/1
    • To start, make sure that the headphones are disconnected from any audio source.
  2. Bowers and Wilkins P5 Headphones Audio Cable Replacement: 2 단계, 이미지 1/1
    • Fold the earpads flat.
  3. Bowers and Wilkins P5 Headphones Audio Cable Replacement: 3 단계, 이미지 1/2 Bowers and Wilkins P5 Headphones Audio Cable Replacement: 3 단계, 이미지 2/2
    • Pull off the earpad.
    • When putting the earpads back on, make sure that the groove in the earpad is facing towards the top of the headphones.
    That's no fix… HowHow to open them now?
    andi fantastico - 답글
  4. Bowers and Wilkins P5 Headphones Audio Cable Replacement, Audio Cable: 4 단계, 이미지 1/1
    • Take the audio cable out of the clip.
  5. Bowers and Wilkins P5 Headphones Audio Cable Replacement: 5 단계, 이미지 1/1
    • Pull out the audio cable.
  6. Bowers and Wilkins P5 Headphones Audio Cable Replacement: 6 단계, 이미지 1/1
    • Headphones remain.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ashley Ryan
회원 가입일: 03/25/12
5,591 평판
안내서 3개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,534개 작성하였습니다
댓글 한 개
I replaced cable once and all was fine. Now left side only not working. Could it be something else or just time for a new cable?
Jayrosen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 29
전체 시간: 9,571
