주요 콘텐츠로 건너뛰기
Bowers and Wilkins T7 Access Panel Replacement
필요한 것
  1. Bowers and Wilkins T7 Access Panel Replacement, Access Panel: 1 단계, 이미지 1/1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Access Panel Replacement: 2 단계, 이미지 1/1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Access Panel Replacement: 3 단계, 이미지 1/2 Bowers and Wilkins T7 Access Panel Replacement: 3 단계, 이미지 2/2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Access Panel Replacement: 4 단계, 이미지 1/2 Bowers and Wilkins T7 Access Panel Replacement: 4 단계, 이미지 2/2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Access Panel Replacement: 5 단계, 이미지 1/3 Bowers and Wilkins T7 Access Panel Replacement: 5 단계, 이미지 2/3 Bowers and Wilkins T7 Access Panel Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shane R. Cowper
회원 가입일: 03/02/17
131 평판
안내서 1개 작성함
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017 회원
USFT-CAGLE-S17S7G1
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 50
전체 시간: 2,746
