소개
This guide will aid you in replacing the clasp to fix a broken bracelet. It will walk you through how to open and close a jump ring and then how to reattach the bracelet clasp. By doing so, you will be able to reattach a bracelet clasp on most types of bracelets for little to no cost.
필요한 것
The clasp and metal ring (jump ring) need to be replaced.
Replace the jump ring first and then the clasp.
Be sure the correct clasp for the bracelet is present.
다른 4명이 해당 안내서를 완성하였습니다.
