주요 콘텐츠로 건너뛰기
Braun 5514 Battery Replacement
필요한 것
  1. Braun 5514 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Battery Replacement: 2 단계, 이미지 1/3 Braun 5514 Battery Replacement: 2 단계, 이미지 2/3 Braun 5514 Battery Replacement: 2 단계, 이미지 3/3
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the four 7.0mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Battery Replacement: 4 단계, 이미지 1/2 Braun 5514 Battery Replacement: 4 단계, 이미지 2/2
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Battery Replacement: 5 단계, 이미지 1/2 Braun 5514 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Battery Replacement: 6 단계, 이미지 1/1
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Battery Replacement: 7 단계, 이미지 1/2 Braun 5514 Battery Replacement: 7 단계, 이미지 2/2
    • Desolder the four tabs connecting the batteries to the circuit board.
    • Repeat for the other side of the battery.
결론
다른 22명이 해당 안내서를 완성하였습니다.
Andrew Kluckhuhn
회원 가입일: 07/05/18
959 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G2, Harley Summer 2018 IUPUI, Team S2-G2, Harley Summer 2018 회원
IUPUI-HARLEY-SU18S2G2
4 회원들
안내서 5개 작성하였습니다
댓글 10개
What is the name/part nr. of the battery?
Casper Smit - 답글
Thanks!
This manual is applicable for the model 5516, too :-)
The battery type should be: AAA 1000 mAh; make sure, to choose batteries, that are prepared for soldering!!
Lucas B - 답글
Same goes for 5515.
Thanks for the guide :)
Yordan Chanev - 답글
Thanks, I was looking how to take apart 5513, similar enough, as far as the battery replacement goes, any rechargeable AAA battery should do. Batteries don’t like the heat from soldering iron, there are kits for welding batteries, another idea is to get cheap battery holder if you can fit it in.
Mariusz Lewicki - 답글
Does the 1.2V Ni-MH AAA 1000mAh battery work, have an older model MGK5280 ?
Thanks.
Jhon Jones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 165
30일 전: 778
전체 시간: 39,795
