주요 콘텐츠로 건너뛰기
Braun Aromaster KF440 Base Replacement
필요한 것
  1. Braun Aromaster KF440 Base Replacement, Access the base: 1 단계, 이미지 1/1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Base Replacement, Remove the nut: 2 단계, 이미지 1/1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Base Replacement, Remove the cover: 3 단계, 이미지 1/1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
결론
Darcy Groom
회원 가입일: 10/19/14
343 평판
안내서 3개 작성하였습니다
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G12
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Can’t remove nut. Soooo small. Plus, clockwise… Or counter clockwise?
Bobbie Savitz - 답글
Das Problem istnicht die das Entfernen der Mutter wie beschrieben, sondern die Schraube die nur mit einem Spezial-Schraubenzieher geloesst werden kann. Und den gibts nicht zu kaufen. Oder?
Udo Doerge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 35
전체 시간: 3,114
