주요 콘텐츠로 건너뛰기
Braun Aromaster KF440 Filter Basket Replacement Guide
필요한 것
  1. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the carafe.: 1 단계, 이미지 1/1
    • Remove the carafe from the coffee maker.
    • Set the carafe aside.
  2. Braun Aromaster KF440 Filter Basket Replacement Guide, Open the filter basket.: 2 단계, 이미지 1/1
    • Grab the ridge on the left side of the coffee maker.
    • Rotate the filter basket to the right.
  3. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket housing.: 3 단계, 이미지 1/1
    • Grab the filter basket firmly and lift upwards. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
  4. Braun Aromaster KF440 Filter Basket Replacement Guide, Loosen the filter basket from its housing.: 4 단계, 이미지 1/1
    • Wedge the plastic opening tool between the filter basket and its housing.
    • Be sure to wedge the tools close to the tab on the right side of the housing.
    • Wiggle tools to loosen the housing from the filter basket.
  5. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket from its housing.: 5 단계, 이미지 1/1
    • Once the filter basket has been pried loose, grab the filter basket and lift it out of the housing.
결론
Darcy Groom
회원 가입일: 10/19/14
343 평판
안내서 3개 작성하였습니다
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G12
3 회원들
안내서 10개 작성하였습니다
댓글 2개
How do you replace the pin in between the coffee carafe and water basket??
janfinochio - 답글
Put the upper hinge first, slide it in and lower to put the back one in. Check this video if in doubt: https://www.youtube.com/watch?v=FP5dKQqD...
Andrés Boza Arce -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 56
전체 시간: 5,706
