주요 콘텐츠로 건너뛰기
Braun Aromaster KF440 one-way valve Replacement
필요한 것
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: 1 단계, 이미지 1/1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: 2 단계, 이미지 1/1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: 3 단계, 이미지 1/1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: 4 단계, 이미지 1/1
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: 5 단계, 이미지 1/1
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: 6 단계, 이미지 1/1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: 7 단계, 이미지 1/1
    • Completely remove one-way valve from the inside of the coffee maker.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Dennis
회원 가입일: 10/20/14
315 평판
안내서 2개 작성하였습니다
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G12
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 30
전체 시간: 3,285
