소개
The removal of the battery is a rather easy process, but very critical when thinking about the use of this razor. Many people will use an electric razor until it dies for the first time, but rather than replacing the battery, they will just buy another electric razor. This is an expensive habit to get into when one can just replace the battery and use the same razor for an extended period of time. With the use of this Replacement Guide, one can easily change the battery in the razor as many times as they would like.
필요한 것
다른 37명이 해당 안내서를 완성하였습니다.
댓글 28개
Where do you buy the Battery?
For example, on Amazon: https://www.amazon.com/Braun-81377206-RE...
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
