주요 콘텐츠로 건너뛰기
Braun Series 7 790cc-7 Battery Replacement
필요한 것
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Braun Series 7 790cc-7 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: 3 단계, 이미지 2개 중 1개 Braun Series 7 790cc-7 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
결론
다른 41명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alex Speer
회원 가입일: 11/07/17
1,099 평판
안내서 1개를 작성함
IUPUI, Team S3-G6, Harley Fall 2017 IUPUI, Team S3-G6, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G6
3 회원들
안내서 9개를 작성함
28가이드 댓글
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - 답글
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - 답글
How do you reset the battery life indicator on the shaver after replacement?
jclemis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 203
지난 30일: 942
전체 시간: 72,176
