소개
Pressing the big power button on an immersion blender (when the immersion blender is plugged in) should power the mixer. But with a damaged motor, the rotational part is not put in motion, making it unable for the immersion blender to operate. Often the motor is affected by dust or water making it unable to repair the motor. Therefore this guide will help to replace a broken motor with a new one and thereby make your blender work again.
필요한 것
Press the side buttons on the mixer at the same time pull the two main parts of the mixer apart. Remove (aluminum) lower part of the mixer.
Place the plier over the metal clip on the circuit board at the end of the brown wire.
Pull back the plier in the opposite direction of the circuit board while clamping the metal clip
Place the plier over the metal clip on the circuit board at the end of the blue colour wire and pull the plier back.
Remove the cord from the hub by pulling the white rubberish part upwards.
After disassembling the mixer, the motor can be put out of the main hull and can be replaced. When the circuit board is again attached to the motor and the mixer is put back together it will work again.
다른 2명이 해당 안내서를 완성하였습니다.
