주요 콘텐츠로 건너뛰기
Braven BRV-1M Motherboard Replacement
필요한 것
  1. Braven BRV-1M Motherboard Replacement, Outer Casing: 1 단계, 이미지 1/1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Motherboard Replacement: 2 단계, 이미지 1/1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Motherboard Replacement: 3 단계, 이미지 1/1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Motherboard Replacement: 6 단계, 이미지 1/1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Motherboard Replacement: 8 단계, 이미지 1/1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
결론
Erik Oliva
회원 가입일: 02/14/18
607 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
i need to eletric scheme!
anonymous 5979 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 254
