소개
A damaged or disconnected motherboard can lead to potential component or entire device failure. One can reference this guide to learn how to successfully remove and replace the motherboard found within the device.
필요한 것
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
거의 끝나갑니다!
결론
