주요 콘텐츠로 건너뛰기
Braven BRV-1M Outer Casing Replacement
필요한 것
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: 2 단계, 이미지 1/1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: 3 단계, 이미지 1/1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: 4 단계, 이미지 1/1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Oliva
회원 가입일: 02/14/18
607 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 624
