주요 콘텐츠로 건너뛰기
Braven BRV-1s Front Speaker Screen Replacement
필요한 것
  1. Braven BRV-1s Front Speaker Screen Replacement, Front Speaker Screen: 1 단계, 이미지 1/2 Braven BRV-1s Front Speaker Screen Replacement, Front Speaker Screen: 1 단계, 이미지 2/2
    • Using a 1.5mm hex screwdriver start unscrewing the 0.6mm screws holding down the front replacement screen
    • Repeat the unscrewing process for the other 7 screws
  2. Braven BRV-1s Front Speaker Screen Replacement: 2 단계, 이미지 1/1
    • Use a plastic spudger to pry off the front speaker screen
  3. Braven BRV-1s Front Speaker Screen Replacement: 3 단계, 이미지 1/1
    • Peel off the front screen using your fingers after using the plastic prying tool/spudger
    • Be careful not to damage the glue underneath the front speaker screen, damaging the glue may cause the device to no longer be waterproof.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Carmelo DeLeon
회원 가입일: 09/28/15
273 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 877
