주요 콘텐츠로 건너뛰기
Braven BRV-1s Speaker Cone Replacement
필요한 것
  1. Braven BRV-1s Speaker Cone Replacement, Outer Casing: 1 단계, 이미지 1/1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Cone Replacement: 2 단계, 이미지 1/1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Cone Replacement: 3 단계, 이미지 1/1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Cone Replacement: 4 단계, 이미지 1/1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Cone Replacement, Speaker Cone: 5 단계, 이미지 1/1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Cone Replacement: 6 단계, 이미지 1/1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Cone Replacement: 7 단계, 이미지 1/2 Braven BRV-1s Speaker Cone Replacement: 7 단계, 이미지 2/2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
결론
Leanne Abel
회원 가입일: 03/06/17
101 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Harley Spring 2017 IUPUI, Team S2-G2, Harley Spring 2017 회원
IUPUI-HARLEY-S17S2G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 725
