소개
This is a step-by-step guide demonstrates how to remove the battery.
WARNING: This is a lithium battery which should be handled with care.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
필요한 것
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 10개
Thank you for the replacement steps - do you know where I could buy a replacement battery?
Anyone ever figure out what battery they needed?
I also would love to know what battery is actually needed for this.
Parallel or series connection?
What is the MAh on the required batteries for this device?
The best batteries are the panasonic 18650 batteries. Do a google search for them. You can usually find them for $8-10 (and higher) each with a little work. The Panasonic brand is definitely more expensive but of superior quality to all the chinese knock off batteries. Will hold a charge better and last much longer on a charge. You will have to connect the batteries and do a little soldering before fitting them back in the container. Two 2600 mAh batteries would equal the OEM rating on this device of 5200 mAh.
The batteries are in Parallel to give 3.7v, and 6800mah (or whatever amp ratting batteries you buy)
18650”s are too big
Good lord this was a chore. Thanks for the writeup!
I have the Braven XXL that is just over 12 Months old. The Battery no longer charges and Zagg (bought out Braven) is offering me a $30 gift card since I’m out of warranty, no thanks. Do you know how I can replace the battery for this unit.
Thanks
Greg Beckler - 답글
