필요한 것
Homemade tool, for the repair of bread toasters, in this case it is the perforator for the mica sheet, which will allow us to insert a screw that will join the two ends of the Nicrom thread, split, it is the 3rd tool that I have made when in fact it should have been the first.
This is the most basic and simple to make, it is the first one we will use in the repair, it is made with a chopstick, a small wood screw and a small nail, both reinforced with instant dry glue.
View of the finished homemade tool, useful to pierce the mica sheet at the point of breakage of the Nicrom thread in toasters and to be able to repair the thread. This tool is a complement of the following tools, being this the first one to be used to make the repair.
This is the 2nd tool that we will use in the repair of toasters with broken or broken nichrome wire, with this one we hold and place the screw: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
This other tool is another option to the homemade tool 2nd is another model of homemade tool for fastening screws: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
This tool will be used to illuminate the inside of the toaster: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
Example of the use of the tools, in this case I used the first ones I made: https://es.ifixit.com/Gu%C3%ADa/TOSTADOR...
This tool is a complement to the homemade tools already published; whose purpose is the repair of broken Nicrom thread in bread toasters:
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
