주요 콘텐츠로 건너뛰기
Brentwood TS-292B Bread Grabber Spring Replacement
필요한 것
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: 1 단계, 이미지 1/2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: 1 단계, 이미지 2/2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: 2 단계, 이미지 1/2 Brentwood TS-292B Bread Grabber Spring Replacement: 2 단계, 이미지 2/2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: 3 단계, 이미지 1/1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: 4 단계, 이미지 1/2 Brentwood TS-292B Bread Grabber Spring Replacement: 4 단계, 이미지 2/2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
결론
Elly Ayala
회원 가입일: 09/21/18
739 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 388
