주요 콘텐츠로 건너뛰기
Brentwood TS-292B Browning Dial Circuitboard Replacement
필요한 것
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 1 단계, 이미지 1/3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 1 단계, 이미지 2/3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 1 단계, 이미지 3/3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: 2 단계, 이미지 1/2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 2 단계, 이미지 2/2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: 3 단계, 이미지 1/1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: 4 단계, 이미지 1/2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 4 단계, 이미지 2/2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: 5 단계, 이미지 1/2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 5 단계, 이미지 2/2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
결론
Elly Ayala
회원 가입일: 09/21/18
739 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 228
