주요 콘텐츠로 건너뛰기
Brentwood TS-292B Power Cable Replacement
필요한 것
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: 1 단계, 이미지 1/1
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. Brentwood TS-292B Power Cable Replacement: 2 단계, 이미지 1/1
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Brentwood TS-292B Power Cable Replacement: 3 단계, 이미지 1/1
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  4. Brentwood TS-292B Power Cable Replacement: 4 단계, 이미지 1/1
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  5. Brentwood TS-292B Power Cable Replacement: 5 단계, 이미지 1/1
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  6. Brentwood TS-292B Power Cable Replacement: 6 단계, 이미지 1/1
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
결론
Elly Ayala
회원 가입일: 09/21/18
739 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 12
전체 시간: 158
