소개
If you are experiencing issues with the lever on your Brentwood TS-292B not functioning properly it might be time to replace it. This guide will lay out an easy to follow step by step process to demonstrate how to properly remove and replace the existing lever of your toaster.
Before beginning this process, the toaster must be unplugged from the outlet.
필요한 것
Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
거의 끝나갑니다!
결론
