주요 콘텐츠로 건너뛰기
Brentwood TS-292B Toasting Lever Replacement
필요한 것
  1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: 1 단계, 이미지 1/2 Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: 1 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
  2. Brentwood TS-292B Toasting Lever Replacement: 2 단계, 이미지 1/3 Brentwood TS-292B Toasting Lever Replacement: 2 단계, 이미지 2/3 Brentwood TS-292B Toasting Lever Replacement: 2 단계, 이미지 3/3
    • Push in the small tab located to the left, and pull the lever tab away from the toaster with force.
    • Remove the toaster cover carefully.
  3. Brentwood TS-292B Toasting Lever Replacement: 3 단계, 이미지 1/1
    • Detach the bundled cable connector by carefully pulling it away from the circuit board.
  4. Brentwood TS-292B Toasting Lever Replacement: 4 단계, 이미지 1/2 Brentwood TS-292B Toasting Lever Replacement: 4 단계, 이미지 2/2
    • Push the tabs in and lift the top of the toaster off.
  5. Brentwood TS-292B Toasting Lever Replacement: 5 단계, 이미지 1/3 Brentwood TS-292B Toasting Lever Replacement: 5 단계, 이미지 2/3 Brentwood TS-292B Toasting Lever Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift up the tab that is located at the front of the toasting lever.
    • Use tweezers to carefully lift up the metal bar.
    • Remove the springs and replace them with new ones.
결론
Elly Ayala
회원 가입일: 09/21/18
739 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 602
