주요 콘텐츠로 건너뛰기
Breville BKC600XL Heating Tank Replacement
필요한 것
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 1 단계, 이미지 1/3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 1 단계, 이미지 2/3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 2 단계, 이미지 1/2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 2 단계, 이미지 2/2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 3 단계, 이미지 1/2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: 4 단계, 이미지 1/2 Breville BKC600XL Heating Tank Replacement, Power Cord: 4 단계, 이미지 2/2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: 5 단계, 이미지 1/2 Breville BKC600XL Heating Tank Replacement, Clear Hose: 5 단계, 이미지 2/2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: 6 단계, 이미지 1/1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Antonio
회원 가입일: 09/26/12
120 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 24
전체 시간: 4,598
