주요 콘텐츠로 건너뛰기
Breville BKC600XL On/Off Switch Replacement
필요한 것
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 1 단계, 이미지 1/3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 1 단계, 이미지 2/3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 2 단계, 이미지 1/2 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 2 단계, 이미지 2/2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 3 단계, 이미지 1/2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: 4 단계, 이미지 1/2 Breville BKC600XL On/Off Switch Replacement, Power Cord: 4 단계, 이미지 2/2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: 5 단계, 이미지 1/1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: 6 단계, 이미지 1/1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Antonio
회원 가입일: 09/26/12
120 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Any source for the switch?
Mark Bell - 답글
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 3,537
