소개
Replacing the water valve should it fail to work.
부품
부품은 필요하지 않습니다.
  1. Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  5. Cut the band connecting the hose to the water valve.
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
결론
Antonio
회원 가입일: 2012년 09월 26일
73 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G3
4 회원들
안내서 6개 작성하였습니다
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 4,594
