주요 콘텐츠로 건너뛰기
Breville BKC600XL Water Valve Replacement
필요한 것
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 1 단계, 이미지 1/3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 1 단계, 이미지 2/3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 1 단계, 이미지 3/3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: 2 단계, 이미지 1/1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: 3 단계, 이미지 1/3 Breville BKC600XL Water Valve Replacement, Silver Casing: 3 단계, 이미지 2/3 Breville BKC600XL Water Valve Replacement, Silver Casing: 3 단계, 이미지 3/3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: 4 단계, 이미지 1/1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
결론
Antonio
회원 가입일: 09/26/12
120 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 5,839
