소개
Replacing the water valve should it fail to work.
필요한 것
Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
Remove the grey plastic casing.
Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
거의 끝나갑니다!
결론
댓글 2개
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Hi same question :)
