주요 콘텐츠로 건너뛰기
Breville JE98XL Juice Fountain Plus Filter Basket Replacement
필요한 것
  1. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Pulp Basket: 1 단계, 이미지 1/1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 2 단계, 이미지 1/1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 3 단계, 이미지 1/1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: 4 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: 4 단계, 이미지 2/2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 5 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 5 단계, 이미지 2/2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
  6. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: 6 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: 6 단계, 이미지 2/2
    • Twist the filter bowl that surrounds the basket in a counterclockwise fashion. Lift the bowl straight up to remove it from the juicer.
  7. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 7 단계, 이미지 1/3 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 7 단계, 이미지 2/3 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 7 단계, 이미지 3/3
    • To remove the filter basket from the surrounding bowl, use a plastic opening tool to create separation between the basket and the bowl.
    • Once there is enough room, place your fingers under the grooves of the filter basket and lift up.
  8. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 8 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 8 단계, 이미지 2/2
    • In order to access the cutting disc, the basket must be removed from the base. To do this, simply lift the basket up and off of the base.
  9. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 9 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 9 단계, 이미지 2/2
    • To remove the cutting disc, unscrew the three Phillips #1 screws.
  10. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 10 단계, 이미지 1/1
    • With all three screws removed, use a plastic opening tool to lift the cutting disc out of the filter basket.
    • The cutting disc has many small and sharp blades. Make sure to hold the disc in between blades when handling.
결론
Madison Burgess
회원 가입일: 10/06/16
499 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-1, Livingston Fall 2016 Cal Poly, Team 15-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G1
3 회원들
안내서 4개 작성하였습니다
댓글 2개
What are the 3 exact screws for this part? Lost one of the screws when taking apart.
Adam Samsonov - 답글
I Twist the filter bowl that surrounds the basket in a counterclockwise fashion. And try Lifting the bowl straight up to remove it from the juicer, but it will not seperate any suggestions?
Robert morris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 1,654
