주요 콘텐츠로 건너뛰기
Breville JE98XL Juice Fountain Plus Food Pusher Replacement
  1. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Pulp Basket: 1 단계, 이미지 1/1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: 2 단계, 이미지 1/1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: 3 단계, 이미지 1/1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Lid: 4 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Lid: 4 단계, 이미지 2/2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Food Pusher Replacement: 5 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement: 5 단계, 이미지 2/2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
  6. Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Food Pusher: 6 단계, 이미지 1/2 Breville JE98XL Juice Fountain Plus Food Pusher Replacement, Food Pusher: 6 단계, 이미지 2/2
    • Place one hand on the food pusher grip, and pull upward. Continue to slide the food pusher until it has fully cleared the food chute.
결론
Madison Burgess
회원 가입일: 10/06/16
499 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-1, Livingston Fall 2016 Cal Poly, Team 15-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 473
