주요 콘텐츠로 건너뛰기
Briggs and Stratton 675 Series Repair Air Filter Replacement
필요한 것
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: 1 단계, 이미지 1/1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: 2 단계, 이미지 1/1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: 3 단계, 이미지 1/1
    • Simply remove the air filter with your hands.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Taichi Nakahara
회원 가입일: 02/02/15
397 평판
안내서 1개 작성함
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G31
4 회원들
안내서 15개 작성하였습니다
댓글 2개
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - 답글
This is a power wash motor water will not come out
hdoggett Doggett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 43
30일 전: 178
전체 시간: 20,265
